The car has had the following work done
injectors removed and seals replaced
FITH injector working fine
new cambelt(timing set correctly)
new metering head in 2004
plugs changed in 2011
rotor arm cap and leads 2011
The co level has been set to 2%
The wiring to the avv and the wur has been checked for supply and seems ok
the wur and the aav have been cleaned out
The ribber o ring on the idle screw has also been re newed.(filter also clear)
the lift pump has been checked for operationn and seems to be working fine
New fuel pump relay
fusebox removed and cleaned out and all fuses replaced with new
relay contacts checked and cleaned
Once the car has started it runs very well and will start every time instantly uness it has been left for a while ie an hour or so wheich again it requires only a small amount of pedal to get it to fire.
I m ust add at this point that i have changed the tank and filler neck as these iteams had become rusty, the fuel filter has also been changed as this was full of crap and small amounts of rust. This starting fault had also occured before all this had been changed to.
My initial thoughts are loss of pressure in the system, timing adustment or maybe a fault with the adjustemnt on the plunger on the metering head????
I am running out of ideas and would welcome any advice you guys have, i am a vw audi mechanic myself but i always like to hear from the experts!!!
If anyone is willing to take a look or do a pressure test on the car i can pay them a few quid and plenty of tea and biscuits!!!
Many thanks guys :
