Number plate lights
steve GT VW
Number plate lights
Post by steve GT VW »
Hi
does anyone know the power level at the number plate lights, I measured it today as 1.5Volts is this correct?
Steve
Re: Number plate lights
They are 12 volts, do you mean the wattage?
steve GT VW
no, both have stopped working I have replacement bulbs, but they dont work, so checked the Voltage at source and got 0.15V dc, so there must be a issue on the wiring some where, any other ideas as where to look?
Steve
Maybe obvious but have you checked the fuse? The numberplate bulbs should be rated 12v 5w.
steve GT VW
Hi Thanks for the help, the Fuse was fine, after checking the wiring for an hour found the earth cable has broken somewhere along the length of cable so to make life easier I took the earth direct from the rear windscreen wiper and hey presto it works, now all I have to do is find some replacement lense covers as the old screws had rusted in and I broke the lenses get the screws out, lol
do you know if the MK1 Golf lenses will fit? or are they available from the dealers still?
many thanks for your help
Steve
GSF sell them (or at least they did when I replaced the one's on my Scala).
Tim_R
Post by Tim_R »
I bought the lenses, screws and bulb holders from the dealers a couple of years ago.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Do these fit? They are for a Mk1 Golf........
http://www.eurocarparts.com/ecp/c/Volks ... 7c2&000512
steve GT VW
managed to get them ordered from VW
cheers for the advice
Steve
