wanna upgrade brakes
lukey
Post by lukey »
after talking to a friend of mine who has a corrardo and is doing a major brake up grade ,he was telling he that i could put rear disks onto my scirocco gt2 ,not only that but i could upgrade the front calipers too .
so after having a think about it i think i might but need some advise on what calipers to get and how to change the rears to disks , i am an engineer by trade so making caliper mounts wont be a problem ? :scratch:
and has anyone done it befor ?????
richlyons
Re: wanna upgrade brakes
Post by richlyons »
thers a post on scirocco uk that tells you everything about this
http://www.sciroccouk.co.uk/
cos of the odd way that site works you cant get a direct link. but you need to go into the forum then Technical Queries then FAQ and Guides and then it the top post, hope it helps, it did for me :hugegrin:
1988 helios blue scala, weber carb, gti cam,
1989 red gt2 (daily)
richlyons
Post by richlyons »
GTXTRA wrote:an FAQ developing here to
http://sciroccoregisterforum.co.uk/faq/ ... 12/test-6/
i couldnt find it :nerner:
Junglist
Post by Junglist »
I'm still on the hunt for calipers to go with g60 280mm discs. Are 1997 golf mk3 vr6 ones correct? Described as 288mm.
tre111
Post by tre111 »
i used caliper adapter plates from the caddy shop on the caddy forum and used early golf mk3 gti callipers and carriers .......cheap and very effective
Junglist
Post by Junglist »
What year does "early" mk3 go up to?
re mk3 golf try here for quicker answer Kieran -
http://www.clubgti.com/forum/forumdisplay.php?f=22
