Fuel pressure - Carb models
steamo
Post by steamo »
I've got to get an electric fuel pump for my carbed GT11 as my new engine does not allow fittment of the original mechanical one. There are two choices of pump, 1.5 - 4 psi or 4 - 7 psi. So does anyone know which would be suitable for a 1.8 rocco.
steamo
Re: Fuel pressure - Carb models
Post by steamo »
For future reference the best info I've discovered is that Weber recommend 3-3.5psi for the dmtl type carbs.
