MK1 Front Number Plate Brackets
Risocco
Post by Risocco »
Hey guys, how do these affix to the bumper on your MK1s and would it be possible to use them on a MK2?
Alex
PeteGLi
Re: MK1 Front Number Plate Brackets
Post by PeteGLi »
L-shaped bracket bolts to the bottom of the bumper.
would be dead easy to make some. bit of flat bar bent into an L shape. 2 of those, bit of flat steel plate welded to them to take the plate, then just drill and bolt thru the bottom of the bumper
Risocco
Post by Risocco »
Nate wrote:would be dead easy to make some. bit of flat bar bent into an L shape. 2 of those, bit of flat steel plate welded to them to take the plate, then just drill and bolt thru the bottom of the bumper
Pretty much what I'm gonna do :good:
Cheers chaps
Alex
