Well, having had her sat outside for the last year and a half I thought it was time to start the restoration. When I bought FAX back in August '07 I knew that she would need a strip down and rebuild in the near future as there was rust evident, particularly in the scuttle and rear beam mounting point.
I used her for a short while before the fuel pump seized. As the rust was also around the pump mounting I deceided to lay her up rather than bodge the repair and have to undo it later, since then she has sat outside but I've had no time to start.
This weekend I started to strip the interior, got the upholstery and dashboard out. Progress will be relatively slow due to other major commitments, but the plan is to ensure I do an hour a week. Hopefully next weekend I can finish removing the wiring and headlining. The rust in the scuttle also appears to have got into the windscreen surround, but not to too bad an extent.
Plan will be to get the shell acid dipped to remove all traces of rust, allowing me to carry out a proper repair and stopping it from rusting again as soon as its on the road. While this is not the cheapest of options it will be much less time consuming and will eradicate all traces of rust. Timeline is to see if I can get to the point of having the shell repaired and sprayed by the year end, which I think is achievable even with my other commitments.
