So having just been dumped out of Uni instead of looking at a new power plant for it I whimsically decided to purchase the Scirocco. I have always really liked the look of them along with all the other early watercooled VW's and they seem more affordable. So with no income I max'd out the credit card jumped on a Mega bus to Sunderland and drove the car home in the first weekend of the snow, it's an 89 Mk2 EX engined carbed GT..
The paint looks good in the pictures having had a recent blow over but what is scary is that no body kit or even door handles were removed for the work! I still think it will buff up good once I sort out what can't be seen!
So basically I have another 80's car that will need some TLC. So I have next to nothing in terms of budget but I can weld and am lucky enough to have my own shop (note the Mk2 Golf shell, a long term project)..
It has M.O.T till the end of January if I can fund tax and insurance I'll drive it and gradually work through what needs done. This is where I am at a loss where to start. Clearly a tyre needed replacing and the car is lumpy on start up possibly extreme weather an influence. I don't know whether to whip out the Pierburg carb and attempt to give it a service or aim to get other stuff done like going all out with the fuel tank and rear beam. Anyway I'll let the pictures tell the story..
Standard 1.8 carbed engine, rusty bits here and there, suspect a cam cover gasket might need replacing..
Rather oily looking carb, hope the breather is OK. Probably needs a real good clean..
Dodgy car alarm which has been disconnected and left to perish..
This bung hole is rotten, going to graft on a Polos spare bonnet piece on each side..
More rust on the tail gate this time, again I am not put off..
Now underneath, front end has evidence of wishbone replacement but not extensively..
Tank looks rusty,as is filler neck. Hope I can get the grinder wire brush cup going and a coat of Rustoleum..
The rear beam, look at Henry's cousin snearing at the state of the rear clips on the ARB bushes..
Finally the rear bench bracket will need a weld..
This will need welded back on..
So the real fear is underneath the body kit. I want to do as much assessment on the inside arches before removing anything.
I can already see rot underneath the rear valance..
Once rust free I want to get loads of Bilt Hamber cavity protection under the plastics and everywhere else possible plus good treatments underneath. I read Practical Classics and have read extensively into rust treatment/prevention so more info will no doubt follow.. A Weber DMTL might well be on the cards if I can't get my head round the Pierburg.
Sorry for all the pics, any advise, questions or comments welcome
MacColl
