Main beam issue on Mk2
So -
the 16v - sidelights and dipped beam - working fine.
on main beam the inner spots work fine but the headlamps switch to side light mode.
car has a BRM headlamp loom, relays all seem fine/not blown - have tried a NOS headlamp switch, same result.
all the other mk2's go - 1 - sidelights, 2 - dipped beam, 3 - main beam on both headlamps/inner spot lamps.
thoughts? Pete?
interestingly the number 9 and 10 main beam fuses that should be 10 amps were infact 3 amp fuses.
thoughts? Pete?
Re: Main beam issue on Mk2
Sounds like a relay problem, any chance you can try a different relay from one of the other cars in your stable?
it's the next logical course i guess, the merseyside derby got in the way of further investigations................
cheers
cheers
bensspares
I had something like this on mk1 with a normal loom, it turned out to be an earth problem with the loom under the bonnet.
I'll need to think about it when my brain has got over the mind numbingly boring Continuing Professional Development seminars I have attended today.GTXTRA wrote:thoughts? Pete?
The fuses in the fusebox only being 3 amps should not be a problem. They will not have much current running through them, given that those circuits now only act as the 'switch'. The fuse for the main beam power, should now be between the battery and the new relay and, depending on whether the relay powers one or both bulbs, will decide its rating.
Amps = Watts divided by Volts
- so a circuit with just one 60 watt bulb would need an 8 or 10 amp fuse.
- both bulbs on the same circuit would need a minimum 15 amp fuse.
GT Matt
It does sound like the relay is either a) knackered or b) not switching over (caused by switching supply not present or poor relay earth) or could be as simple as both bulbs (as suggested earlier) as it isn't common for two bulbs to fail at the same time.
Check for a 12v supply at the bulb when you select main beam. If it's there, it's more than likely the bulbs. If not, start checking the relays
Hope this helps
Matt
Hope this helps
Matt
GT Matt
1988 Mk2 GTX
1988 Mk2 GTX
don't know how the headlights are wired up with the uprated loom, as i've only had experience of uprated looms that i have built myself. i would assume there is a relay for high beam for each side of the car - i.e. left main beam and spot light are wired together, as are the right main beam and spot. this would mean it will either be a broken wire between the relay and the bulb, or the bulbs have blown
- Jay4424
Seconded. Don't be looking for the fuse in the normal place, it'll be within the new loom!PeteGLi wrote:I'll need to think about it when my brain has got over the mind numbingly boring Continuing Professional Development seminars I have attended today.GTXTRA wrote:thoughts? Pete?
Failing that, has it been working? (something failed) or has it never worked right (wired up wrong?)
Jay.
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
If the fuse to the relay is ok, then it sounds like the main beam filament may have gone in the dip/main bulb/s.
Try a bulb that you know both filaments work.
tomorrow hopefully - will be swapping relays between the two cars with brm looms and take it from there.
ok.
switched relays between the two brm loomed cars. made no difference to either car. 16v relays fitted to the 2- litre worked the loom fine - i.e when operating lights 1 = side-lights, 2 = dipped, 3 = main beam on both headlamps and inner spot lights.
changed both bulbs. no difference.
fitted spare indicator/main beam/flasher stalk(that had been working fine on the car it came off). no difference.
GT Matt
Does still sound suspiciously like switched or earth wiring at the relays rather than the relays themselves.
What's the exact set-up? Is it one relay per side of car or one relay for dipped and one relay for main beam or a single relay for the lot?
4 or 5 pin relays?
Got any photo's?
If only you were closer to Derby.................
4 or 5 pin relays?
Got any photo's?
GT Matt
1988 Mk2 GTX
1988 Mk2 GTX
hi matt - its a three relay set up.
pretty sure they are 4 pin relays.
tbh - it's off to the phirm on 5th february where along with getting its new boots and a new exhaust it'll be having an mot next door - pretty sure that tim will be able to sort this for me or can always disconnect it and go back to standard for mot.
