As I said really.
We bought the car with a fault (honestly admitted by the PO)
Now it's worse and I really think it's time to act before it's undrivable.
1.8i Scala
Had a look on Vag cat and it suggests a host AEN,4S,AUG 8A,9A,4Y; 4K,AGB:"J.."
But I'd like a definitive code to put up in the wanted forum
Which code gearbox for my '90 scala
Re: Which code gearbox for my '90 scala
If you get under the front of the car and look at the bellhousing, you will see a flat rectangular area that if you clean, will show you the code of the gearbox you currently have fitted.
If you still have the sticker in the boot, that will also give you the gearbox code.
Old Mac Rocco
This is the sticker you are looking for in the boot.
On this car it was below the nearside light cluster.
And in this case it is a 4Y gearbox.
Hope this helps.
Hope this helps.
