Few updates...
Im missing the G40 ECU from the setup and few other bits.. So rather than spending the money on buying parts to get it running short term ive been looking at other ignition solutions so I can run it on the 5 GT turbo carb. The options are listed below..
1. 5 GT Turbo renix ignition
2. Early Saab 900 Turbo dizzy that advances on vacuum but also retards on boost
3. Megajolt standlone ignition ECU
After reading up on Kjet turbos on VWVortex I found out I can use an early VW Rabbit dizzy vacuum canister and this will also retard the ignition on boost.. I manged to sorce a NOS canister from a very friendly chap on Vortex.. So I intend to fit this to a mk2 Golf 1.3 dizzy.. wish me luck lol
My mate welded my engine mount in for me in its new location so it would be rude not trial fit the engine.. It all very tight at the front end and on the bonnet but lots of ground clearance
![Image](http://i64.photobucket.com/albums/h175/76ball/Mk1%20Scirocco%20Blog/IMG_1123.jpg)
