Engine Conversion - 2.0L AGG??
haddock_n_chips
Post by haddock_n_chips »
Hey
I have been thinking for a while about converting the engine to something a bit bigger in the rocco
I have found a 2.0l AGG engine with low miles and close to me
i have no idea where to start with this one so all and any info would be appreciated!!
How much of an arse would it be to do this?
Bear in mind the car is currently the 1.6 with 4+e gearbox
Help!!!!
WiLL......
Re: Engine Conversion - 2.0L AGG??
is that the low revving passat engine? if it is, find yourself a 2E ;)
if it isn't, get the whole car if you can, then you don't need to worry about not having enough wiring.
alternatively, you will need to extract the engine loom and ecu and probably the clocks if the car has an immobiliser.
haddock_n_chips
well engine is out of car already but complete with everything, so loom, ecu and air box etc....
haddock_n_chips
oh and think (not 100% sure) that it is out of a MK3 Goof gti? not the passat
sciroccosi
Post by sciroccosi »
Hi mate the agg is out of a 1997 golf gti same as im putting in my mk2 golf gti
