buying new brake linkage parts
nye
Post by nye »
i took all my brake linkage to peices a while ago for a rebuild and i have lost the washers/bushes and also two of the brake pins that hold the triangle parts in place ( very technical description :yup: )
so basically could anyone tell me where i could get replacements????? also if anyone has a diagram showing how they all go together so can work out which parts im missing that would be great,
cheers liam
marcus
Re: buying new brake linkage parts
Post by marcus »
There's a diagram on page 188 of the Haynes manual.
I suspect only VW will have these, failing that you may have to take the missing bits off a donor car.
1985 GTL 1.8
