Spark Plug GAP
jonkennedy
Spark Plug GAP
Post by jonkennedy »
i just bought some BOSCH SUPER 4 plugs
the gap is set at .9mm and it needs to be .7 or .8 right ?
well, looking at the plug its impossible to change..
http://washford.scene7.com/is-viewers/f ... ze=450,507
HELP !
wasted
Re: Spark Plug GAP
Post by wasted »
No need to change the gap on multi-electrode plugs. Pop them in as they are.
jonkennedy
Re: Spark Plug GAP
wasted wrote:No need to change the gap on multi-electrode plugs. Pop them in as they are.
thanks so much !
bensspares
Re: Spark Plug GAP
Post by bensspares »
the correct plug gap is 0.7/0.8 mm
jonkennedy
Re: Spark Plug GAP
bensspares wrote:the correct plug gap is 0.7/0.8 mm
thats what i thought but its impossible to change the 4 way ones
bensspares
Re: Spark Plug GAP
there is a tool available from factors but i carefully use molegrips.works for me.
jonkennedy
Re: Spark Plug GAP
bensspares wrote:there is a tool available from factors but i carefully use molegrips.works for me.
yikes...
i think i'll attempt to run it as they are and see how it feels before getting mole grips out !
bensspares
Re: Spark Plug GAP
took me a few years to perfect the molegrip method lol
wasted
Re: Spark Plug GAP
Post by wasted »
I always buy either Bosch or NGK multiple-electrode plugs - the gap is usually 0.9mm or thereabouts, and I've not had any problems with them at all.
jonkennedy
Re: Spark Plug GAP
wasted wrote:I always buy either Bosch or NGK multiple-electrode plugs - the gap is usually 0.9mm or thereabouts, and I've not had any problems with them at all.
good to hear
they look well fancy too !
