in line fuel filter
tinkerbel
in line fuel filter
Post by tinkerbel »
fuel filterin line with the arrow on,in Haynes book it says against the flow, seen one on one of the threads, going the opposite way, with the arrow pointing , going down towards the pump, does it make any difference which way. :read: Tinkerbel
Re: in line fuel filter
normally the arrow points in the direction the fuel flows. check with the shop you bought it from :)
