g60 brake upgrade for mk2 scirocco
jaques_g60
Post by jaques_g60 »
Im looking to upgrade the brakes on my scirocco when i do my engine conversion. just wondering if anybody has done this conversion themselves and any problems they have come across? any help would be much appreciated :)
MK2 Scirocco - 1.8T 8v project
Chaps
Re: g60 brake upgrade for mk2 scirocco
Post by Chaps »
make sure you get the adaptor plates for the calipers. you wont be able to fit them otherwise.
stu.gtx
Post by stu.gtx »
As far as I'm aware it's a bolt on upgrade, as long as you have the right calipers/pads, caddyforum brackets and 280mm discs of course. I have this set up waiting to go on mine. Only other thing is you need minimum 15inch wheels to clear the bigger set-up.
towey86
Post by towey86 »
I'm looking to put g60's on my scala...
Many post about it but im a little confused as to what i need...
Would any1 mine posting a shopping list of all the things i need to buy?
Cheers guys
If it ain't rocco. It ain't S**T!!
280mm calipers
280mm pads and discs
Adapters from just caddy
Some cheese
Quite a few floating about on the eBay and the adapters are forty odd quid straight from the shop. Jackpot
jaques_g60
cheers for the help. just got the callipers and carriers. just gotta get the other bits and then should be attempting this fairly soon :D
