So the new engine has arrived and is sat in the garage eagerly awaiting the weekend. Ive enlisted the help of a few mates and a crane etc. However i want to replace the engine and gearbox mounts but looking on GSF there are so many different ones im rather confused. Also want to do the cam belt at the same time but again looking at the Mark 3 Golf belts and tensioners the list is endless. Can anyopne point me in the right direction of the correct parts?
best bet for the timing belt kit would be to just ring them and ask for a kit for your particular engine. would help if you knew the registration of the donor car, but they should be able to find it from the engine code
i got one of those engines!!! i ave got to wait till next year tho to get cracking on mine as im having an extension on the side o my house and therefore have no space. can you keep a list of the parts you use to get it to fit as i will probly follow the same method of fittment. gud luck buddy.
james
Yeah no worries James, all the bits will be listed on my project thread, unfrotunately some welding has brought things grinding to a hlt for the last week but hoping this weekend there will be some progress
