Difficulties fitting rear Springs?
MJK 24
Post by MJK 24 »
Has anyone come across any uncompatibility issues with Scirocco rear Springs?
I just bought a lowering kit from GSF and the rear springs wouldn't seat in the rear shock base spring pan. The tops were fine.
I had this exact same issue many years ago.
My dampers are Boge Turbogas by the way.
Re: Difficulties fitting rear Springs?
MJK 24 wrote: the rear springs wouldn't seat in the rear shock base spring pan.
how so? spring diameter too big/small?
have you definately got it the right way up? (sorry, i have to ask)
MJK 24
Post by MJK 24 »
Diameter too small.
I've had this problem about ten years back with Scirocco rear springs. I have returned them for a refund and will try another brand and report back.
