Where do I get adjustable n/s track rod?
Junglist
Post by Junglist »
I'm replacing my o/s track rod as it's rusted fast to the track rod end. While I'm at it I want to swap the non-adjustable n/s one for an adjustable one but it's shorter. Where can I get one? I know they exist because people have done this replacement before.
Cheers.
Re: Where do I get adjustable n/s track rod?
gsf, europrats or main agent will all be able to get them for you
Junglist
Post by Junglist »
GSF can't help. I was in there today.
PeteGLi
Post by PeteGLi »
Person in GSF obviously did not look hard enough !
435VG0320 TIE ROD-BQ SC 2/74 > 14.50
436VG0280 TIE ROD END-BQ SC 2/74 > 6.50
You need both of these.
Junglist
Post by Junglist »
No mate, that's the o/s one and you don't need both, the tie rod end comes with it. The n/s one is shorter. That's the part i'm after and can't find.
originaly, the car had 1 fixed and 1 adjustable. as far as i'm aware, you can't buy the fixed one as a replacement part, so you buy the adjustable one and fit it to the 'wrong' side of the car
am i the only one thinking that gsf ain't as good as they used to be?
Junglist
Post by Junglist »
But they're different lengths so you can't just fit the off side one to the near side, it won't fit.
europrats are listing 1 track rod that fits both sides. surely the reason the fixed one is longer is that there isn't then a balljoint end to screw onto it - it's built in. vagcat isn't working at the moment, so can't look it up on there
PeteGLi
Post by PeteGLi »
Junglist wrote:But they're different lengths so you can't just fit the off side one to the near side, it won't fit.
It will fit - I think Haynes tells you what the dimensions should be. Screw the track rod end on until you get the right measurement.
Junglist
Post by Junglist »
Oh right. I'll get two the same then. Cheers.
don't forget to slap the muppet in gsf ;)
