Weber gargling/sploshing - normal?
Junglist
Post by Junglist »
I had the bonnet open with the engine running the other day and noticed the carb was making a lot of noise splashing the fuel around and glugging/gargling noises. Is that normal or is something wrong? The car seems to be running OK but I can even hear it from inside the car when I'm sitting at the lights. Kind of sounds like a drain or gutter or something.
LEEP
Re: Weber gargling/sploshing - normal?
Post by LEEP »
could be the rubber mount the carb sits on maybe thats split and makeing that noise if the carbs moving to the side when driving just a guess mind :dash:
SCIROCCO GT
Member 934
Junglist
Post by Junglist »
I'll look into that but it's not been on long. I replaced the last one because it split.
if the car is running right, ignore it so long as there are no extrnal fuel leaks. my weber used to make an odd sclurrrping noise.
Junglist
Post by Junglist »
Yeah, that's the noise! So it's normal then? Cheers. Hey, Nate - see if you can answer my question in ICE section - I know you're the electricals geek of the forum! Cheers matey.
Junglist wrote:I know you're the electricals geek of the forum!
if only you knew the truth! i once rewired a fusebox after a small loom fire using only brown and blue cable (3 guesses what that came from!) all worked, but i'd hate to have to trace an electrical fault on the car :hehe:
