bulbs!
Rusty dan
bulbs!
Post by Rusty dan »
I am being a frank I think....
Can someone give the bulb numbers needed for my scirocco mk2. My old lamps were sold and my gti lamps did not have bulbs in them..
Any assistance appreciated. By the looks of it I have 4 connectors one for the indicator, a 3 pin and two 2 pin.
cheers ears
insanecreations.net
Junglist
Re: bulbs!
Post by Junglist »
should be etched or embossed on the lens. It'll be H4 probably and indicator bulbs are pretty much the same on all cars - single contact single filament level pin bayonet. Can't remember the number but i'll check in work tomorrow. I can send you some for free and get you the headlight ones cheap too.
Re: bulbs!
Headlamps defo H4's, indicators as Kieran says.
Jay4424
Re: bulbs!
Post by Jay4424 »
inner spots are H2 arn't they? or are they H1?
...outers def H4.
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
Re: bulbs!
main headlight, 3 pin connector, H4 bulb
spot, 2 pin connector, H7 bulb (i think!)
indicator R382 12v 21w (pins opposite each other, not staggered)
Junglist
Re: bulbs!
Post by Junglist »
H7 souunds moe likely. Most cars are H4 or H7. H1 and H3 are rarer and I've never known any others on cars. Do you want me to send you a full set of what you need?
Jay4424
Re: bulbs!
Post by Jay4424 »
Junglist wrote:H7 souunds moe likely. Most cars are H4 or H7. H1 and H3 are rarer and I've never known any others on cars. Do you want me to send you a full set of what you need?
ah, sorry, the H1s are one my converted capri lights!
'52 BSA A10
'03 Suzuki GSX1400
PeteGLi
Re: bulbs!
Post by PeteGLi »
Later Mk 2
The dip/main bulb in the outer rectangular headlight is an H4 - 12v,60/55w
Inner square driving headlight is an H3 - 12v,55w
Early Mk 2 with the twin rectangular headlights - same outer bulb - H4, but the inner lamp is an H1, 12v,55w.
Mk 1 round headlights are all H1
Rusty dan
Re: bulbs!
Post by Rusty dan »
bloody hell!
I was expecting one answer! You guys are the best :beers:
insanecreations.net
Junglist
Re: bulbs!
Post by Junglist »
I'll send you a set if you like. PM me and I'll give you a price for the lot posted.
