Scirocco mk2 gti x reg
Reverend Frog
Re: Scirocco mk2 gti x reg
Post by Reverend Frog »
I don't mind admitting that I am quite riddled with jealousy
Previously owned:
1988 1.6 GT
1989 1.8 GT
1982 1.6 GTI
1993 Corrado VR6
Dr. Dub
Post by Dr. Dub »
Yay, another GTI is saved. :beers:
That looks tastier than a bowl of red hot Texas chilli. In my humble opinion, the early quad lamp GTI is THE perfect Mk2 Scirocco. Looking forward to see this all cleaned up. Have you considered one of these kinds of firms to fix the cracked dash? http://www.qualitysmart.co.uk/page_1238016883546.html Maybe a little going over with some rubbing compound like Farecla G3 will get rid of those rust stains as well.
Very nice and super rare. :vcool:
Mum, can I have one? Can I? Please. I'll be a good boy. :blush:
breezespeed
Post by breezespeed »
Fitted a new battery today with the mother of all hang overs...
The knakered old one..
Tidy battery tray..
Shiney new one..
Starts first time now.
While i had the bonnet open i topped up the washer bottle ready for the MOT. The front washers work lovely but there was nowt coming from the rear one.
After a quick rummage in the boot i found the rear washer bottle and topped it up whilst soaking the boot floor.
Now the motors working but still no water other than a puddle forming on the drive from a steady drip just behind the rear wheel.
I pulled the washer jet out only to find that there was no pipe connected to it. So how do you get at the pipe to reconnect it from the inside of the car?
DT1
Post by DT1 »
You remove the washer jet and the bottle (so you can stick your hand up the wing).
Probably best to renew the pipe (you can get cheap 5mm tubing from B&Q) and connect it to the jet then feed the pipe from the top until you can grab it.
Pull it through, trim it and connect it to the pump on the bottle and put it all back together.
Glad you didn't have the algae problem I had.
breezespeed
DT1 wrote:You remove the washer jet and the bottle (so you can stick your hand up the wing).
Thanks for that. I'll have a look at it in the morning.
Started looking for classic car insurance for it, any suggestions?
breezespeed wrote:Started looking for classic car insurance for it, any suggestions?
Lancaster always the best for me.
breezespeed
Insurance sorted.
Lancaster for £105.
Just the MOT and tax to go...
I bought the 5mm tubing from the dealer, cheaper than B & Q. Heat the end up with a lighter, fits on easier.
Whitescala89
Post by Whitescala89 »
Replacing the washer tubes under the bonnet was my first job on the scala. I wondered why the offside jet wasnt working and found that over time the washer pipe had become brittle and broken in about 4 places so replaced it all with shiny new pipe. Try dipping it in a cup of boiling water for about 15 seconds. It goes on very easily then.
to go with your new battery, it would be worth cleaning the terminal clamps up and then giving them a smear of vaseline (not copper grease)
breezespeed
Nate wrote:to go with your new battery, it would be worth cleaning the terminal clamps up and then giving them a smear of vaseline (not copper grease)
Rodger that. I was a bit pushed for time when i fitted it , thats a job for the weekend.
MOT booked 15:30 on Thursday... parpp...
Reverend Frog
Good luck! I think you should definitely set up a thread in the projects forum for this beauty
Previously owned:
1988 1.6 GT
1989 1.8 GT
1982 1.6 GTI
1993 Corrado VR6
andy69
Post by andy69 »
Love this car feller; best of luck with it! :good:
1986 Mk2 1.6GT tintop
1977 Type 2 Devonette
Post by Ryan »
Moved and pruned :ok:
breezespeed
i thank you.
