Can you tell me if around 180 psi is roughly what the compression should be on a 1.8i DX engine?
Have been told that this is a good figure if all cylinders are more or less equal.
Compression Test
scirocogtx
Re: Compression Test
Its a nice healthy figure!
My 16v is a nice 200psi on each cylinder so 180 is good
VW Scirocco 16V GTX, Kamei X1 and a half
scirocogtx
Ok, thanks.
Was thinking I had a headgasket problem but compression test shows probably not. :)
Have had a good look and it seems that my rad is weeping.
1986 Monza Gtx
1989 Scala
1989 Scala
MrD
Were your results = across all cylinders ? Have got quite a lot of variation in mine,and was your test done wet at full throttle ? as did mine dry and closed
scirocogtx
Dry test and at open throttle, allows full air to compress. I removed fuel pump relay and fuse. 180psi (+/- 5) across all in two tests when engine warm.
1986 Monza Gtx
1989 Scala
1989 Scala
