Project Vr6
skintseagull
Project Vr6
Post by skintseagull »
Well here goes will post up pics and details as i get on with project,will be up grading brakes,electric assisted steering,and the VR6 conversion possibly with a twist? . The start remove the engine, gearbox ,rad , driveshafts and give the engine bay a quick jet wash .Image
Risocco
Re: Project Vr6
Post by Risocco »
Oh hell yeah! This is gonna be interesting! Good luck dude!
Alex
andy69
Re: Project Vr6
Post by andy69 »
That's gonna be bonkers!!! :hehe:
1986 Mk2 1.6GT tintop
1977 Type 2 Devonette
skintseagull
Re: Project Vr6
Thanks for replies,just picked up handbrake cables ready to convert rear brakes to discs,and new brake pipes ,will post some more pics up when i have got some more done ,Cheers Paul
skintseagull
Re: Project Vr6
Mocked up engine and box in the car this morning,to see what needs moving etc.The engine needs to go to the o/s by around 2/3" this will happen as soon as i cut the mounting bracket off the chassis.I am off the old school check double check then cut .Image
Funky Diver
Re: Project Vr6
Post by Funky Diver »
Looks quite neat in really :P
Looking forward to the final fit
skintseagull
Re: Project Vr6
Been busy and removed the interior ready for the storm interior i have ,and also as a precaution for some welding it will require,rear drum brake assemblys removed ready for disc conversion,dirverside engine mounting removed from chassis to allow alignment of engine and gearbox to scirocco driveshafts with only the inner joint needing swapping over ,much to my amazement,Next engine mount fabrication Image
Re: Project Vr6
this is gonna be one hell of a speed demon. good luck m8 :good:
skintseagull
Re: Project Vr6
james butler wrote:this is gonna be one hell of a speed demon. good luck m8 :good:
Thanks James. Well the drive shafts are sorted ,been busy collecting bits for the car including corsa electric power steering,all the bits for disc brake conversion for the rear,new fuel lines ,clutch fluid res ,mastercylinder and servo,fuel pump ,rear section of wiring loom and tank,and loads of silly odds ,Will post some pics up soon Cheers Paul
