My scirocco has been off the road since christmas. Its been into a so called vw specialist and they said it was the carb needing set up. They couldnt do it because they didnt have a amitions tester.
I then took it to another garadge that did, they set up the carb and the same thing was happening. The car will run for hours but as soon as you drive for more than ten minutes, it dies and wont start again until a few hours later. I took it back, they stripped the carb, tryed again and the same thing happened. I've changed the distriburator, distriburator cap, rotor arm, leads, spark plugs, battery, and the alternator. The guy recons there could be something in the fuel tank and that the fuel tank has to come out? I trust this guys mechanical skills but i've seen that some of you say that you can get in from under the back seats? He says you cant...
Please help
