fuel additive?
fuel additive?
does anybody know if it is recommended to add fuel additive to unleaded petrol in my 1990 GtII? it has a weber conversion if this makes any difference?
Re: fuel additive?
No Volkswagen built after 1977 (ish) needs leaded petrol. It is the octane rating that the car needs and these were designed to run on 98 ron, so I would recommend using Tesco 99 ron or Shell V-Power, these have the higher octane rating than normal unleaded at 95 ron.
I am sure others will put comments on here as well, all valid and useful information.
Re: fuel additive?
I use Tesco standard unleaded in my fleet and they all still go like s**t off a shovel
Re: fuel additive?
Niall wrote:Does the place you get it really make a difference?
yup, some are cheaperer than others
![hehe :hehe:](./images/smilies/laugh2.gif)
![ok :ok:](./images/smilies/ok.gif)
Re: fuel additive?
I agree with Pete, my GTI stipulates 98 RON but 95 is usually just fine, the only time you'd need to step up to 98 is if your engine is pinking a lot.
Re: fuel additive?
http://www.sciroccoregisterforum.co.uk/ ... =17&t=2055MickyS wrote:pinking?
I use 98RON in my Scirocco. It would probably be ok on 95RON but as I don't do epic mileages the cost over the year is unlikely to be significantly different.
Last edited by the edmundator on Fri Aug 14, 2009 7:48 pm, edited 1 time in total.
Re: fuel additive?
I could not get my DX engine Mk1 Golf GTi to run well on 95 Ron petrol, lumply tick over and felt flat to drive I now use 97 Ron super unleaded from supermarkets and it so much better.
- Junglist
Re: fuel additive?
I've said this a few times, but higher octane is more economical to the point where it actually works out costing less overall compared to standard unleaded. There's no point putting standard in your car, especially if the timing is set for 98 plus RON. You'll lose both economy and power.
![Image](http://i583.photobucket.com/albums/ss279/Sciroc/GTII.jpg)
![Image](http://i583.photobucket.com/albums/ss279/Sciroc/bleh.gif)
Re: fuel additive?
i always found standard duel gave me significantly more miles between trips to the pump. the full fat stuff always ended up making the car get driven much much much harder
irrelevant now, as i run a diesel
![hugegrin :hugegrin:](./images/smilies/biggrin.gif)
Re: fuel additive?
I've been using bog standard Total unleaded for a bit and my Scala i seems to thrive on it ![yup :yup:](./images/smilies/derisive.gif)
Danny
Re: fuel additive?
Don't use any additives but I do use 98 or 99-RON, and I do notice the difference between that and normal unleaded.
