I'll be looking for some new tyres once I've painted my newly aquired rims, but I have no idea what the sizes mean or what is a standard size.
175/70 R14 H (84). So what would this mean? I assume 14 is the size of the wheel it's going on.
Also, what's a standardish size for a standard 14 inch steel Scirocco wheel?
Can someone explain tyre sizes to me?
Re: Can someone explain tyre sizes to me?
175/70 R14 H (84
175 tyre width in mm
70 - tyre sidewall profile – sidewall height expressed as a percentage of its width
r radial
h speed rating i think up to 130 mph
r radial
Im not an expert but I believe that the sizes mean, 175 is the measurement across the tyre width in mm, 70 is the size in mm from the rim to the tyre tread R14 is the size of the wheel rim in inches, H is the speed rating , (84) No idea!!
My tyres on the standard Scirocco 14 inch wheels are 185/60/14 ( H)
I think there is a link on the opening page on the scirocco register that tell you all and more that you ever wanted to know about tyre sizes and wheels.
Here you go Luke - http://sciroccoregisterforum.co.uk/faq/ ... -you-need/
- Funky Diver
aaaah, Car Bibles... a car geeks number one dream website
- Ryan
84 will be the load rating I believe.
Edit - heavier the car = higher load rating
