ever since i got my brake pads and shoes renewed the braking is uneven the nose goes down and then it rocks back when you come to a halt?
![ire :ire:](./images/smilies/ireful.gif)
it does this no matter how slow you're going or how gently you brake?
any ideas?
back brakes do near enough bugger on the footbrake anyways. iirc it's less than 3/4 of the brake effort on the rear and the rest on the front.DannyH wrote: could it be that the back brakes are not coming on enough which is pitching it more forward?
you may find that the rear brakes are out of adjustment. adjust them properly (or get someone to do it for you) don't just tighten up the handbrake cable.DannyH wrote: the handbrake has been a bit soft since as well.
