help
LEEP
help
Post by LEEP »
right peeps
hope some one can help
just done a 300mile round trip to the lakes in the rocco all i can same i love them roads the car ran perfect all the way there and back until about 10 mile from home then when i stopped at lights etc the revs when up to about 1.5 to 2 thousand revs but if i kicked the thottle it went bact to normal had a look nothing catching any happy please
lee :ire:
SCIROCCO GT
Member 934
dozzum
Re: help
Post by dozzum »
When mine did that it was a loose vacume hose.
Risocco
Re: help
Post by Risocco »
Throttle cable and butterfly OK bud?
Alex
Brunty
Re: help
Post by Brunty »
Carb innit?
Take the airbox off and squirt a load of carb cleaner down. There could be some manky gummed oil stopping the butterfly from closing properly.
Brunty
LEEP
Re: help
Post by LEEP »
cheers chaps i will check :hugegrin:
SCIROCCO GT
Member 934
mclean83
Re: help
Post by mclean83 »
Check where the throttle cabel attaches onto the pedal, the 'hook' on the end of the cable sits into a rubber grommet type thing, on mine this had disintegrated meaning the throttle was stuck on slightly all the time as there was always a bit of tension on the cable, but if I lifted the pedal up with my toe the idle settled to normal. Eventually the hooked worked its way out completely and I was left with no throttle on Bradford ring road. Nice. :hugegrin:
MrD
Re: help
Post by MrD »
That happend to me too,was allways popping out,think i bunged a cable tie around it,to stop it.
