head untit problem
head untit problem
hi all i wonder if you can help me, our alpine unit cuts out, it was doing it before i had a mp 6x9s and sub put in, it was working fine but recantly it cuts out and goes off, it does it when i turn it up as in shorts out and comes back on again, it does it some times when i put the heater on, i was thinking of takeing it to our local auto electrsion but i thought i try on here frist of all, could be the a wire going to the rocker cover as my brothers machnic mest this up with not putting the seal in the side of the rocker cover and it liked oil all over the engine there for this earth wire might need cleaning thats if there is 1 on there after fitting a webber carb cuss loads of the electrics go from the peco 1, we have recantly had a webber carb put on, can any 1 help please many thanx.
Re: head untit problem
I'm far from an expert but if it does it when you turn it up is it drawing too much power?
Nate's normally quite a genius when it comes to the Devils power so he'll probobaly know a solution, maybe a power cap?
loose wire or dodgy earth. pull the stereo out and check all connections are secure. if scotchloks have been used to install it, shoot the person who fitted them and then solder all the joints properly
ok i have turned up way loader then what it is before.and it has not cut out, as for the contections it has been screw plugged typed up with electric type, and pluged toghter with proper car stereo conectors i will check the earths today, i have had the head unit out reacenly and had a look and spreyed all with elecric conect cleaner.
ideally the only plug would be the plug into the back of the unit. all other joins between the stereo's loom and the original car loom should be soldered and insulated with heat shrink
ok well i have booked for the fist of december with a auto electrsion, she all so has indercator, hazzerd, back windscreen whiper problem.
markh
If you were having that many electrical problems bud, i'd guess theres an earthing problem.
ok many thanx, well back wipper stays on here when its hot in the summer time, when she is parked up outside, after i frist start her up, inercaters stay on stuck on right side sometimes when it rains, and the hazzerds sgo off after about 2 mins, and the stereo cuts out sometimes and comes back on when it is turned up.
Might be worth checking the fuse box for signs of water damage. Possible leaky screen?
