engine swap, mk2 to mk1
83mars
Post by 83mars »
im hoping to be attempting this in the next few days,
just wondering if a mk2 golf engine will fit relatively easy into a mk1 scirocco.
from pics ive seen of the mk1 engines im presuming its just a case of swapping mounts, am i wrong??
cheers for any advice.
Rusty dan
Re: engine swap, mk2 to mk1
Post by Rusty dan »
swap the mounts, what engine are we talking about though? depends on gearbox too whether its rod or cable change.
insanecreations.net
83mars
Post by 83mars »
mk2 golf 1.6 diesel,
rod and cable box.
the car itself is a heap, so its a patch an go type of job...
cheers
Rusty dan
Post by Rusty dan »
hmm do they have a rear engine mount or do they mount on the gearbox at the back?
insanecreations.net
83mars
Post by 83mars »
if your talking about the golf, i make em out like this:
front middle, rear left(just behind the belts)and rear right(end of the gearbox to the back)
had a quick look monday and looks like ill have a bit of work with the gearbox mount, hoping a mount from a mk2 will do for the t-belt to chassis leg.
mite get a chance to see properly tomorow
