Removing rear side windows on MK1s
mikeki
Post by mikeki »
:dunno: Hi
Does anyone know how to remove the rear side lights from a MK1, the metal trim inserts look easy enough to remove, it is the metal strip that runs along the top of the window I am not sure about that is colour coded to match the rest of the bodywork Any suggestions anyone or do I need to get a specialist in? I have a set of tinted windows from a GLS that I want to put in, done the doors already, which was reasonably ok.
Thanks for any help you might be able to give.
Regards
Mikeki :help:
Mk1 Storm 1981...sold
Mk1 GT(GLS) French Version 1978...still under development
Mk1 GLS 1980...sold
MK1 Golf GLi Cabriolet
MkII GT 1991....nice and quiet
Mad as a badger...and getting worse!! Much worse! This is not looking good is it ! Is there a cure?
Re: Removing rear side windows on MK1s
Post by Ryan »
I've not done this BUT - I know you'll nee dto proceed with caution.
There are a small number of clips that hold that metal trim in, and they are unobtainium...and of course are easy to lose into the ether of your mk1 when you remove the trims!
PM Ant (AUTOAD) - He's done this not so ong ago on his mk1...
The Autoad
Post by The Autoad »
Wrap a screwdriver in masking tape to protect your paint, open the door, and prize the rear window metal (boomerang shaped) surround from the edge nearest the door first to pop it off the first few clips. You should then be able to pop it all off easily with your fingers. As Ryan said, careful with those clips, I have searched high and low for replacements and cannot find any sources, so you will need to re-use your old clips. You will also need to remove the B-pillar trim too, same as above to remove. Push it from the edge that 'wraps' into the inside of the B-pillar.
Once the boomerang surround is off, the rear window is very easy to take out- just ease it out at the top edge, pulling towards you. It will be a bit stubborn at first but will again pop out, chrome trim and all.
When swapping the chrome trim over, I found it easier to slide the bottom edge trim into the window rubber channel first, then ease the longer piece into its channel.
Refiting is a faff - Wind some fairly thin rope around the circumference of the window rubber and rest the window into its aperture. Have an assistant (glamorous) push against the window from the outside as you pull on the rope from inside the car, easing the rubber back over its aperture. Start in the rearmost corner if you can, as its the most difficult bit.
The boomerang piece of trim and the B-pillar trim just clips back in.
