Removing the bodykit
Rocco Ben
Post by Rocco Ben »
i really like the look of the early mk2s when they had no body kit. but i'vee seen it done to later models. like this:
http://img.photobucket.com/albums/v133/ ... 290012.jpg
anyhoo. could i take mine off and polish it up?
or am i wasting my time and looking for a disaster! :dash: (how is it stuck on?)
and if i do take it off and it goes wrong could i put it back on with too much drama?
cheers :)
Ben
Re: Removing the bodykit
Before you take it off, have a good feel around the insides of the wheel arches and look at the edges of the sills - if there's any feel of rough edges or signs of rustyness, leave the kit where it is unless you fancy some welding. It's easy enough to put it back, but I think you'll need some Tiger Seal or similar to stick it back in place.
as Ed says do check the arches.
i have just done this to an 87 GTX - see A20 GTX Project thread - but i had kept a careful eye on the inner wheel arches on a regular basis.
just got to get rid of all the gunk and in time the mounting holes for the kit will need to be filled at paintshop stage.
captquo
Post by captquo »
I had mine removed and the scrapes fixed, and then re-sprayed. The bodyshop said they used cheese wire to cut it off where it was joined to the body of the car.
1986 GT S
Rusty dan
Post by Rusty dan »
liking the cheese wire technique! :beers:
Was thinking of this myself but felt my arches and they are going :shock:
Maybe a year down the line to save a bit of weight I will get the kit off and prepare for the worst.
I can only assume if there is rust coming from above the kit then it would be gone below it :(
insanecreations.net
