Installing 3rd high level brake light
littlePaul2
Post by littlePaul2 »
Hi guys, can anyone help identify what wire is the rear brake light in the Mk2 scirocco... I need to tap into power a red LED high level light, but not sure which is which... thanks in advance...
LP :help:
littlePaul2
Re: Installing 3rd high level brake light
or if its even possible to do it without blowing the car up?!?!?
:help:
LP
Tim_R
Post by Tim_R »
Black and red according to Haynes wiring diagram.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
littlePaul2
Tim_R wrote:Black and red according to Haynes wiring diagram.
Cheers Tim- will have a look over the weekend and see how easily it is to blow up a scirocco :)
littlePaul2
Job done.
Tapped into the red and black with the positive and tapped into the black nagative with the negative... hey presto, I have more LED's fitted...
I have the front Audi type white LED's at the bottom corners of the bumper, a couple of inches in from the actual corner, which looks quite nice, at the risk of being a bit tacky I figured I would move them, but I think they make the car look lower and wider - so they are staying...
I have fitted LED bulbs to the indicators, and the stop lights - so I have the "instant on/instant off look" from behind which I really like :) but the indicators flash twice the speed they should, not got my head around where to/how to fit the resistor yet... but that can wait for now...
Also, fitted white LED bulbs on the inside of the cabin, so I get a crisp white light when the doors open, and I had a spare blue one which is in the boot - but that will be getting changed to white as its a little too tacky for my liking :)
Now with the high level LED's fitted, the back of the car should look "current" now... but we wil see when I am out and about properly as still not driving anywhere with the gear linkage issues...
so about a million LED's later - I am nearly done with the lights... kinda... :) I had a LED kit for the dash, but cant find it :dunno: so I was thinking setting up some kind of white LED set up behind the dash so it glows white... hmmmmmm...
:newbie:
littlePaul2 wrote:Job done.
have you checked other lights all work as they should when the brake lights are on? i wouldn't swear to it, but i thougt the earth to the rear clusters was brown and not black :scratch:
littlePaul2
Yup - everything works ok... :) Here is a clip I did of the high level light - its still to be mounted properly (hence it looks a little saggy still) but I was tempted to install it into the spoiler... I think that would give a good affect... but i want to test on a spare spoiler 1st... so I can butcher without worry :)
http://www.youtube.com/watch?v=E1uvkjJFXU8
LP
:newbie:
type53b
Post by type53b »
http://www.youtube.com/watch?v=E1uvkjJFXU8 where did u get the 3rd brake light mate? it looks like a nice mod. :ok:
LP
:newbie:
