How does an Amp work? How do you wire amps up? Do they power subs or speakers too? Would you recomend a sub? Do I know my arse from my elbow? ect....
Cheers guys
Alex
it takes a really quiet "line level" signal from your head unit from the phono plugs on the back and makes it loads louder so it'll be heard thru your speakersRisocco wrote:How does an Amp work?
really simple. on the power side you have an earth which goes via a big chunky brown or black cable to the chassis, the main power wire which is red, similarly chunky and goes via a fuse to the battery +ve terminal and finally a small blue "trigger" which connects to your head unit. this turns the amp on and off with the head unit. you've then got connections for 1, 2 or 4 speakers, depending on the amp. then there'll be 2 pono sockets for connecting to the phono sockets on your head unit.Risocco wrote:How do you wire amps up?
either or both. depends how involved you want to get. basically, a high power amp running at 10% volume will give you clearer sound than a low power amp running flat outRisocco wrote:Do they power subs or speakers too?
oh god yes. even sarah thinks they should be standard on all vehiclesRisocco wrote:Would you recomend a sub?
Sarah wrote:they even make the archers sound better
possibly notRisocco wrote:Do I know my arse from my elbow?
your kidding right? you play in umteen bands as a... guitarist? ...you play electric right? ... youget amplified right?Risocco wrote:Mr Funk has inspired me, I think the Golf needs an install. Not into BOOM BOOM music so epic bass aint really the goal here, but if somebody could explain the very basics, I'd really appreciate it.
Cheers guys![]()
Alex
