Bodgit and Scarper Bulkhead Clutch Cable Repair
Slugga
Post by Slugga »
Working on ze vehicle today and discovered this beauty of a repair job...
Where the original panel has damaged, someone has welded a repair plate in place over the original panel.
Two problems:
1. No rust proofing was done to the repair so it looks proper shi*ty now.
2. The now double panel width means that the rubber grommet part of the clutch cable has become distorted, stretched, etc.
So I think the best course of action is to remove both the original and repair plate and weld in a replacement.
Can you buy a weld in metal repair plate or just the plastic stick on jobbies?
Am I just best off fabricating a repair plate myself?
scalainj
Re: Bodgit and Scarper Bulkhead Clutch Cable Repair
Post by scalainj »
You are best off fabricating your own plate to weld over and give it strength
Bulkhead is notoriosly weak and as its gone and been plated then your will have a large weak area and the repair plates will not hold that
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
MikeH
Post by MikeH »
If the metal's reasonably thick, I'd be tempted to clean it up and paint it. Depends if you're building a show car or not, really.
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
Slugga
Post by Slugga »
Not a show car, Mike. More of a track weapon that looks tidy!
I pondered this but the inside is pretty bad (not pictured)
I'd rather do it proper than have to revisit it x number of years down the line....
Do it nice or do it twice.
