i dont know any thing about the electric side of the cooling system so any help would be fantastic
temp gauge doesnt work
as the tittle says really, i had the engine out to get a new gearbox in and when i put it all back together the temp gauge doesnt work, the red led blinks at me, but thats all, it fired up first time
replaced every thing the same.
1988 helios blue scala, weber carb, gti cam,
1989 red gt2 (daily)
Re: temp gauge doesnt work
Check to see if the little connector is fitted. it is a single wire connected to a terminal near the plugs.
If it is give it a rub down with some emery cloth.
