New Heater Blower Fitting
teenspirit7
Post by teenspirit7 »
Hi,
I've come a bit stuck trying to replace my heater blower.
I'm planning to take it out via the bonnet (rain tray). To remove the front wiper motor do I need to first remove the wiper arms? I've removed the nuts but it won't budge.
I've been trying to follow eefy's guide but just can't remove the motor.
Images to jog your memories
https://imgur.com/a/l3DZH
Thanks for reading.
eefy
Re: New Heater Blower Fitting
Post by eefy »
yeah you'll need to wiper arms, once the bolts off it should pull off, the wiper arm is connected with a spline joint, this might just be bumped up and may need some persuasion. Some light tapping with a hammer may help. Once there off the whole wiper motor needs to be removed, the raintray on the passenger side is widened to allow this.
the heater motor then needs to be split in two, its a bit fiddle to get it our in 2 parts but it will some out again on the passenger side.
Goodluck
Heath
teenspirit7
Thanks for the help. Managed to get it fixed! Now I'll actually be able to see out of the windscreen.
eefy
Post by eefy »
Glad its all sorted :)
C 20 CCO
Post by C 20 CCO »
Glad you fixed it..................................
It may help to put a tiny amount of copper grease on the spline before refitting the wiper arms; not too much but enough to help make it easier to remove next time. The splines get furred up over a long period of time and can be difficult to remove unless you have a set a arm pullers.
kind regards,
Dave.
To be old and wise......
rosie
Post by rosie »
I've also been following eefy's guide today and have got as far as taking out the old motor (god knows how I'm going to get the new one back in - plenty of swearing so far!)
My new motor is apparently the right one, but the wiring is different. As per the photo
The original motor has a pair of yellow wires on one connector and a brown wire on the other.
The new motor, on the right in the second photo, has a plug with two prongs - one attached to a red wire and the other to a brown wire. (sorry the picture doesn't show the wires very well)
Presumably I attach my yellow spade connector to one of the prongs and the brown connector to the other but please can someone tell me which way round they go?
Thanks so much.
1992 GTII 1.8 black
Brighton
Running it into the ground
GT_II
Post by GT_II »
Brown is VW's colour code for earth (negative) and red for live (positive). Yellow here would be the switched live, which would be full battery voltage at maximum fan speed or a fraction of battery voltage at lower fan speeds. So brown to brown, yellow to red should do it.
rosie
Post by rosie »
Awesome. Thanks for the help.
1992 GTII 1.8 black
Brighton
p in phcas
Post by p in phcas »
Resurrecting - My heater blower is on it's last legs and will need replacing in the spring. eefy's guide link seems to go to a dead end now. Does anyone have a new link or instructions as to how to remove / replace the blower?
Also, it seems a common part for Mk1 golf, T2.5, and other VW of the 80s / 90s - any gotchas in buying from AutoDoc or other non-OEM manufactuers?
the easiest way is to remove the wiper mechanism as its in the way when trying to remove the blower motor complete
to remove the wiper arms, remove plastic nut covers at the base of the arms and undo the 10/13mm nuts
give the arms a little wiggle and they should come free from the spindles
next remove the massive nuts that hold the wiper arm spindles to the scuttle
next remove the rain tray under the bonnet to get access to the wiper motor mech and blower
remove the remaining 10mm screws from the wiper mech holding it in place in the scuttle
now you can unplug the wiper motor mech and remove completely from the car
to remove blower motor remove the single screw at the front and unplug motor
the motor should now pull free
as for a new motor i would get one from mark carter of classic vw
https://www.classic-vw.co.uk/heater-blo ... 4773-p.asp
When you have the wiper arms off the spindles give them a good clean with a wire brush so they are nice and clean when re fitting the wiper arms.
Also a good time to re-grease the wiper mechanism.
p in phcas
I know this is an old thread, but update from me, having to go through replacement of the unit. I bought a Febi replacement and it looks exactly the same.
Getting it out of the heater recess and then the scuttle tray was impossible. I had to separate the case of the motor housing and get it out in two parts. Wiper assembly was fiddly to get out, but it is removed.
I have to install the new one and it seems the same, so I will have split it into two parts and hope I can get it re-assembled in situ.
Haynes says remove the heater matrix and drop the whole unit from inside the dash - big job!
Any one have any tips?
nows a good time to be doing it as its much hotter, the plastic wont be as brittle but yes you do have to split the casings in order to fit through the scuttle.
removing the wiper mech is a good idea and as above a good chance to refurb the wiper mech.
take your time and it will be a fairly straight forward job, dont forget to seal up around where the blower fits to the housing and scuttle as its also a known leak point for water
p in phcas
Job done. Note to others. Getting the old blower out is mostly a destructive process as clips break on the old plastic and it is a bit of a faf rotating the blower around to get to each clip. Don't expect it to come out unscathed.
Split the new blower on the bench, put the motor bit in first, then the cover and clip them together.
The wiper arm is also troublesome getting it back with the blower due to the position of the blower below the bodywork hole. Patience and some brute force is will find it's way in.
On a separate note, the plastic scuttle tray /cover is fragile. I have one of the pattern ones that were on sale here a few years ago but heat and weather has made it brittle. Looks like I will be needing a new one again ..... soon!
