rattling noise help
Cloudzackff7
rattling noise help
Hi I'm wondering if anyone can help me out with this problem basically I park my car up last night and noticed it was making a rattling noise coming from the engine bay as I put my car into reverse it was making the noise a bit louder I asked my mate to see if you can see where it was coming from in the engine bay but it was hard to point out anyone got any ideas? I have attached a video with the sound it is making it is a 1.4tsi 2012 plate
here is a vid of it making the sound
https://youtu.be/LtV8505LWaM
- GT_II
Re: rattling noise help
I'm no expert on engines, but I personally wouldn't drive the car until it's been seen by a specialist. A failing belt tensioner springs to mind as a possibility, which could cause sudden expensive engine failure if it's the timing belt tensioner that's on its way out.
Cloudzackff7
yeah i have left it on the drive for now and been looking into it some say it could be the timing chain
Do you have the lead and software (Vagcom) to read the engine fault codes as it may tell you what’s wrong?
And as above I would advise not to drive the car till you have some idea what’s wrong.
Quick google (searched golf as lots of those around) and timing chain does get mentioned a few times but I’m not familiar with the 1.4 tsi engine as not owned one before so can’t be 100% sure.
- GT_II
Good point mark1gls. Any major faults detected would also be flagged up with at least an amber warning light - eg camshaft position sensor failed. Anything minor, maybe not. But with a strange noise like that, don't assume the absence of a warning light means it's safe to drive!mark1gls wrote: Tue Aug 17, 2021 8:15 pm Do you have the lead and software (Vagcom) to read the engine fault codes as it may tell you what’s wrong?
Cloudzackff7
I do have a lead but i don't have the software at the min its over the road at a garage dropped it off last night the guy will call me later todaymark1gls wrote: Tue Aug 17, 2021 8:15 pm Do you have the lead and software (Vagcom) to read the engine fault codes as it may tell you what’s wrong?
will keep you guys posted......
Cloudzackff7
update the guy has looked at my car he said its definitely not the timing chain he said the noise is more a water pump problem was told £35 to have checked and looked at he said the sound is coming from the bearing below if it was the timing chain it would sound more on top then it coming from the lower of the car
going to get it booked next week and take it from there
so it rules out timing chain..........
Cloudzackff7
Updated guys turns out it was the water pump one of the bearings have gone got myself a new one from Euro car and had it fitted Scirocco is running fine now and no more rattling noise
Cheers for your help
- GT_II
Glad it's solved at hopefully not too much cost.
