Good news bad news day, got her bum in the air to drop the rear beam and replace bushes etc.
Decided last night to replace the brake flexis front and rear as they were still OE rubber ones, which is good as they are seized on at the beam end.
Managed to get the axle pivot bracket nuts off and the lower suspension bolts and nuts too.
Bad news front, offside handbrake cable is completely fecked so I might as well replace both. Fuel tank breather has corroded through to the inner arch, both of the front sections of the rear sills have corroded - not too badly that it can't be cleaned up for now and treated with the long term job being welding in some new metal.
Also found some corrosion on the front inner face of the fuel filter area after removing the rubber grommet from the filler flap.
Previous owner has got black mastic happy at some point on the nearside front end of the rear arch to try and cover up some further rot.
Looking at a of the rot it's all tied to a lack of cleaning the mud build up in the arches - compounded by a crappy lowering kit which further restricts access.
So a little grumpy as wasn't expecting any rot to be more than a bit of recoverable surface.
Decided to clean up and paint the rear beam too whilst it's out - I don't plan on going back in there at a later date.
Sent from my Pixel 2 XL using Tapatalk
