Clutch cable - again!
Radorocco
Re: Clutch cable - again!
Post by Radorocco »
Yay, cable fitted and we're back on the road.
Slight moment of concern when I discovered the clips on the gearbox end had disappeared. Amazingly my local car parts had a set :-o
Cheers and thanks for the help and advice
Jeff
The Triumph Twins - 1973 GT6 and 1980 Dolomite 1850HL
The Karmann Krew - 1986 'Rocco GTX, 1995 Corrado 2.0
MGB roadster - the "Dark Side"
A picture of a correctly fitted clutch cable:
daveyheats
Post by daveyheats »
Sorry for trawling another ancient post up from the depths, but I'm currently trying to track down a new clutch cable for a K-Jet myself and having no joy. Does anyone know of any currently available, or can VW dealers still get hold of them?
Mad that they're so hard to come by, particularly when they seem so prone to snapping due to bulkhead cheese wiring.
I've not got a Mk2 so not 100% sure and it does not state the length in the description so might be worth sending them an email?
https://www.heritagepartscentre.com/uk/ ... drive.html
Reading the earlier posts you need 1490mm ish?
I think this one is to short?
https://www.heritagepartscentre.com/uk/ ... k-jet.html
Kdc169
Post by Kdc169 »
around 20£ posted, i can double check part of my injection/carb mk2s
daveyheats
Kdc169 wrote: Mon Feb 01, 2021 11:19 pm around 20£ posted, i can double check part of my injection/carb mk2s
If you've got one the right length consider it sold good sir!
