Car was then laid up for maybe 4 months.
On bringing her out of hibernation the idle speed has now dropped to 200-300 but occasionally, usually after a brief period of high revs, the Idle speed will return to around 950 then when clutch depressed or car stopped and restarted Idle speed drops to 200-300...
Cleaned the metering head again, plenty of fresh fuel over 800 miles this year. Should mention that the screw to adjust Idle on throttle body is fully closed (due to previously reducing Idle speed)
Any ideas..? Sounds like something is sticking...
Saw the forgotten GTX resto thread and thought maybe a faulty microswitch. Bit expensive if it's not €45 + shipping
Thank you for help
