https://www.vwheritage.com/321906059f-f ... e-vw-spare
is there any reason why this would not fit a DX engine, Scala Inj?
Fuel Pump Relay
Re: Fuel Pump Relay
Should fit but not 100% sure, more info here..
https://www.ebay.co.uk/itm/MK1-GOLF-Fue ... Swcjhap-CM
If you can get a genuine VW one as the aftermarket ones are poor quality, none on eBay at the moment but if in dire need then get one and see if a Vw one turns up later. I found a cheap one by searching the relay number, mine is a 62 relay, search Mk1 Golf cabriolet as well.
Re: Fuel Pump Relay
I bought a new one from VW Classic Parts a year or two ago. Might still be available.
Re: Fuel Pump Relay
Re: Fuel Pump Relay
Possibly worth pointing out that the right part for DX engine cars is this one, which is also half the price from VW:
https://www.volkswagen-classic-parts.de ... ronic.html
Relay 62, 321 906 059 G
