Just fitted a recon Bosch alternator 65amp from euro car parts . Started up no charge light on , thought good it’s working then checked voltage 12.5 and going down, so not working. Charge light now not working on ignition start up, it did with the old alternator. I have measured the voltage +pillar to the the battery and it’s the same as at the battery terminals. I then disconnected the +Pilar and measured accross to the alternator casing 0.85v
![Sad :-(](./images/smilies/icon_e_sad.gif)
Thanks njl1968
