87 Black GTX
Re: 87 Black GTX
Coming along nicely - my own black car has a similar homebrew throttle cable guide and the Phrim solved the servo/bottle issue with a just about fitted nicely reservoir from a mk3 polo (the updated breadvan era ones) if you look at my A16GTX thread.
Good luck with the final stages!
BlackGTX
Re: 87 Black GTX
Post by BlackGTX »
GTXTRA wrote:Coming along nicely - my own black car has a similar homebrew throttle cable guide and the Phrim solved the servo/bottle issue with a just about fitted nicely reservoir from a mk3 polo (the updated breadvan era ones) if you look at my A16GTX thread.
One of these?
8v 1.3 around 100bhp 800kg
Been working on these for about 10 years, im assuming they had to make a new copper arrangement for the compensators?
As it happens i should have a spare polo master cylinder and res. I have got a scirocco one now so would like to keep it as simple as possible at the mo
BlackGTX
Re: 87 Black GTX
Post by BlackGTX »
Heres an out of focus picture of the bay, has some improvised wiring and vaccume hose at the mo
This was a short while after, fitted the replacement rocco res
Also noticed this, the engine has sat for along time and diesnt turn that often so its posible its condensation but ill keep an eye on it as it seems to be thicker than what ive seen in the past
BlackGTX
Re: 87 Black GTX
Post by BlackGTX »
Did this today aswel as the eyebrow spoiler
The other didnt come out so well, sanded it back a few times but the paint always moved away from spots
I may also tint the black stripes on the rear lights with it
BlackGTX
Re: 87 Black GTX
Post by BlackGTX »
Re: 87 Black GTX
Armour door plates look good, how did you prep them for the paint?
I’ve a set of door plates that need painting.
BlackGTX
Re: 87 Black GTX
Post by BlackGTX »
They were keyed and zinc primered and then painted black ages ago so cleaned and keyed then fresh black, flip laquer and normal laquer
Ill probably go over them with a light tinting spray to darken them for a black car
BlackGTX
Re: 87 Black GTX
Post by BlackGTX »
This is still ongoing, just fitted the 9" servo
Quick list of whats been done since purchase i guess to see where we are at, not going to include what i did to the dx engine
• gt2 front and rear seats
• boot lock seal & number plate lights
• chrome boot catch
• clear indicators & side repeators
• sunroof seal & ally lifters to be fitted
• under bonnet sound deadening
• new fuel tank
• ap coilovers
• eyebrow spoiler - to be fitted
• large washer bottle to run light washers too - to be fitted
• polo g40 leather steering wheel & spline adaptor - to be fitted
• ACE 2l 16v engine, DX clutch fly and gearbox.
• SA clutch cable kit - to be fitted
• scirocco 16v inlet and brackets
• abf throttle body & scirocco 16v cable holder. Golf 1.3 cable
• scirocco 16v inductuon boot
• scirocco 16v metering head, fuel lines & injectors. Dx airbox
• heritage 421 stainless manifold heat wrapped and jettex exhaust, twin tip
• scirocco 16v engine loom rebuilt and mk2 golf gti ecu
• 9" brake servo
• 90° dizzy & 8mm ht leads
Already done to the car when i got it
• 256 front discs and rear disc conversion
• braided brake hoses
• polly bushed rack
• upper lower & rear strut braces
• twin slim fans & new radiator
• tripple guage fitted, oil pressure temp and volts
• banded steels 8j front 9j rear
• rear wiper delete and hole filled
BlackGTX
Re: 87 Black GTX
Post by BlackGTX »
Started replacing the wishbones and adding the poly bushes, set the camber to -1
BlackGTX
Re: 87 Black GTX
Post by BlackGTX »
Judt a quick pic,
This is some plastic tubing over the injector lines to stop tha braiding rubbing through the loom or anything else
BlackGTX
Re: 87 Black GTX
Post by BlackGTX »
We have a full bay, all things fit. Brake res with sensor, dizzy and leads too
BlackGTX
Re: 87 Black GTX
Post by BlackGTX »
Fired it up on sat, had forgot to put the inlet vac hose on
https://youtu.be/rjZC6926nUc
