Alex
Lightened Flywheel
- Risocco
Lightened Flywheel
Evening gents. Has anybody done the above? Really like the idea of it just wondered what your thoughts were on the subject, or if anybody has any experience of the modification, that would be awesome too
Alex
Alex
Re: Lightened Flywheel
I don't think that just lightening the flywheel on its own will do much good. In fact, it may do more harm. Ideally, you should get the whole crankshaft and clutch assembly balanced so that the unit as a whole, rotates smoothly without vibration.
- Risocco
Hey Pete, cheers for that. I'm off to see a man about head-work so I'll have a word while I'm there. Have you ever had a flywheel lightened dude?PeteGLi wrote:I don't think that just lightening the flywheel on its own will do much good. In fact, it may do more harm. Ideally, you should get the whole crankshaft and clutch assembly balanced so that the unit as a whole, rotates smoothly without vibration.
Alex
I had one made for my racing car. In general a lightened flywheel will help with top end speed but reduce acceleration, at least from a standing start. I regularly made up several places off the grid simply because I was one of the few people without a lightened flywheel. Only problem was keeping them all. You definitely need to get it balanced.
jrabarton
wow thats bizzare, i always thought a lightened fly wheel increased th acceleration and decreased the top end ... damm you forza motorsport you lied to me.
- Risocco
Yeah me toojrabarton wrote:wow thats bizzare, i always thought a lightened fly wheel increased th acceleration and decreased the top end ... damm you forza motorsport you lied to me.
Cheers Ed, this may well go on the back-burner in that case
Alex
- scalainj
I've had on my road car for a long while now. Other than an utter pain when the engine is cold as the flywheel mass won't keep the engine spinning so it stalls its been fine.
Means for me a very quick throttle response so for example i can blip the throttle very quickly as the rev rise and fall is very quick indeed and bump starts can be done at walking pace or even a slight slope from a rolling start which balances out the stalling. Fine when run for 5 minutes or more
I didn't balance anything except the flywheel although i had an uprated clutch. Worked on the basis that VW had done that all for me when they made the bottom end. Seems to be ok. Probably best to follow the advice though.
Can't remember the exact weight left after work or what was taken off but it was many kgs of metal. I'm struggling to think how many years ago this was done. About 8 I reckon
Can't comment on whether its faster acclerating as i did major head work at the same time which increased redline and power so maybe it does accelerate slower than a normal one.
I think my top speed is less - just a guess as i've never tested it at all. Never ever. Not even once
Andy
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
I might be wrong about this... I would consult an expert. There might be one around here somewhere (I haven't noticed Doug T from the states pitching up yet...). I am not an expert.
I think I might have been talking cobblers. Have a read of this:
http://www.pumaracing.co.uk/FLYWHEEL.htm
jrabarton
Hallelujah
my faith in xbox racing games has been restored.
Yes, the flywheel on my EG code 1.6 GLi engine was lightened when Brian Ricketts rebuilt the whole engine. Smoothest engine I've ever driven.Risocco wrote:Hey Pete, cheers for that. I'm off to see a man about head-work so I'll have a word while I'm there. Have you ever had a flywheel lightened dude?PeteGLi wrote:I don't think that just lightening the flywheel on its own will do much good. In fact, it may do more harm. Ideally, you should get the whole crankshaft and clutch assembly balanced so that the unit as a whole, rotates smoothly without vibration.
Alex
- Risocco
OK no worries, cheers for the input matey, think I'll leave this a bit and get the crank done to match it.PeteGLi wrote:Yes, the flywheel on my EG code 1.6 GLi engine was lightened when Brian Ricketts rebuilt the whole engine. Smoothest engine I've ever driven.Risocco wrote:Hey Pete, cheers for that. I'm off to see a man about head-work so I'll have a word while I'm there. Have you ever had a flywheel lightened dude?PeteGLi wrote:I don't think that just lightening the flywheel on its own will do much good. In fact, it may do more harm. Ideally, you should get the whole crankshaft and clutch assembly balanced so that the unit as a whole, rotates smoothly without vibration.
Alex
Just one more question, did you feel much improvement with the lightened flywheel?
Alex
MikeH
An 020 flywheel weighs about 5kg as standard, and you can get them down to about 3kg.
This helps acceleration in 1st and 2nd gear, but isn't really noticeable above that. David Vizard did a really good explanation of the effects of flywheel lightening on performance in his 'How to Modify Your Mini' book, back in the '70s.
Based on mini gearing ratios, he found that removing 1kg from the flywheel was the equivalent of removing about 10kg from the weight of the car in first gear, then progressively less according to gear ratios, as you go up the 'box. That calculation won't be right for a VW, but the principle is the same.
The downside is that you'll find it easier to stall the car when moving off, you might need to adjust tickover, and might lose some idle stability, based on my experiences with a Mk2 Golf 2.0 16v.
If the flywheel is balanced to itself, you won't have an issue with vibration. A decent machine shop will balance the fly to a tighter spec than the factory did, and the factory wouldn't have balanced the flywheel and clutch together (or at least, none of the several engine factories I've worked in ever did it). However, on a competition car, balancing with the rest of the crank assembly will probably prolong the life of your engine at high RPM.
It's marginal whether it's worth it on a road car. If you're trackdaying or racing, then it's more of a benefit.
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
- Risocco
Hi MikeH, so you wouldn't recomend it for a daily driver dude? Cheers for the input tho mate
Alex
Alex
MikeH
It's marginal on a daily - handy for the traffic light grand prix, but not much use otherwise!
Having said that, I'm putting one on mine, when I change the clutch, because I've got one spare.
