Fuel Filler Cap
nolegjoe
Fuel Filler Cap
Post by nolegjoe »
Had a new fuel filler neck installed recently that I got from a very helpful guy on this forum. Only problem is, the old fuel filler cap doesn't fit. Seems the opening on the new neck is too tight! The various ones I've found at Euro Car Parts and Halfords are no good either. Anyone got any ideas? I'm stuck with a slowly disintegrating temporary cap for now.
Thanks!
Jack92
Site Admin
Re: Fuel Filler Cap
Post by Jack92 »
Who was it that you got it from? probably worth reaching out to them directly and seeing what they advise.
Jack
South East
VW Scirocco Scala MK2 1.8 Inj
VW Transporter Camper
nolegjoe
Re: Fuel Filler Cap
Post by nolegjoe »
User BlackGTX. I've sent him a message. Just wondering if anyone else has a tip?
Cheers.
essextom
Re: Fuel Filler Cap
Post by essextom »
Have you tried lubricating the black rubber seal on the underside of the cap?
Re: Fuel Filler Cap
Do you have a picture of the end of the new filler neck?
BlackGTX
Re: Fuel Filler Cap
Post by BlackGTX »
Ill check through all my caps, mine had one on it before i started the work, surely i have another to fit
BillyBob780
Location: Moved... North Warwickshire.. well by Nuneaton
Re: Fuel Filler Cap
Post by BillyBob780 »
Strangely on the petrol cap front. I cant get one to fit, the filler neck on mine seems far over to the left side of the filler area at an angle. The ones Ive bought dont fit in a month of Sundays.
Re: Fuel Filler Cap
Is it a stainless steel one?
The early batches of those that were floating around years ago, like one I’ve got, used an Astra mk2 cap for some reason.
BillyBob780
Re: Fuel Filler Cap
Ill have a closer look when the weathers better. Losing the faith in it at the moment.....
essextom
Re: Fuel Filler Cap
Post by essextom »
BillyBob780 wrote:Strangely on the petrol cap front. I cant get one to fit, the filler neck on mine seems far over to the left side of the filler area at an angle. The ones Ive bought dont fit in a month of Sundays.
Is yours new? My old one was a modified mk1 golf neck and it sat over to one side.
BillyBob780
Re: Fuel Filler Cap
To be fair Im not sure. I bought it early last year from a man in Manchester. I dont think he or the owner before him did anything to it. So to be honest I havent got a clue.
Re: Fuel Filler Cap
i think its where the tang that locks into the filler neck that causes the issue as well.
i seem to remember using a dremel to sand the tang down a bit to fit properly.
i think crusty has a bmw filler cap from an e36.
BillyBob780
Re: Fuel Filler Cap
Ill have a look..... when its above -2 outside...
nolegjoe
Re: Fuel Filler Cap
Post by nolegjoe »
Trying a mk1 Golf cap I found on eBay. Will report if it's any good or not.
The problem I seem to be having with mine is that there are two flanges inside the neck at the bayonet fitting locks against. These flanges stick out too much for most caps I've found so far so the locking pins on the cap can't get behind them. Shaving them down would likely fix the issue, but there's no way I'm trying that with it still attached to the car, and I don't have the tools to take it off myself.
BillyBob780
Re: Fuel Filler Cap
Ive used one off a mk1 Beetle. Seems ok.
