I'm thinking that the dash lights are just burned out, as I've replaced all the fuses for them. The low beams however are a different story. The bulbs obviously work, since only the high beams will function.
We've replace the fuse for the headlights and hoped that would fix the problem. Fuse pictured below.
My turn signal, my passenger side one (which is your driver side one) has recently been flashing extremely fast, and while the front one works, the rear doesn't. When I started it up the other day, it fixed itself and now all turn signals work fine.
Any help would be appreciated!
