My 1.6GT has an issue where the revs will stick at around 3k rpm. Sometimes it does it, sometimes it doesn't. Had a look and there's a diaphragm that pushes a flap open on the left hand side of the carb (opposite side to the throttle) and when I press this the revs drop.
Few places have suggested vacuum leak on one of the pipes or an o-ring that needs replacing.
Has anyone got a bit more info on how to rebuild the carb? Or would I be better off spending the time converting to something like a twin webber?
Thanks, Liam.
Pierberg 2e2 carb Vacuum issue
liam_0404
'88 Scirocco 1.6 8v GT
‘94 Golf 2.8 12v VR6
'02 Grand Cherokee Limited 4.0 I6
'07 Golf GTI 2.0T
'07 Golf GTI 2.0T
- unknownmale
Re: Pierberg 2e2 carb Vacuum issue
As you'll find when looking around the forums, not many people know how to work on these so tend to switch to a Weber dmtl 32/34 as they're simpler to work on. Or if you want to stick with it there is a service manual here: http://vwa1.dadoghouse.com/wp-content/u ... uction.pdf
- David
