Mk2 headliner
Mk2 headliner
Anyone have any experience of replacing a headliner in a mk2? Any tips or know where I can get one from? Looking at doing mine as it's the only thing letting the interior down! Really don't want to take the windscreen out to do it.
1988 Mk2 Scirocco Scala 1.8t AGU - now sold
teenspirit7
Re: Mk2 headliner
Thanks, gunna try and do it my self if I can.... Must be mad ha.
Found this online, only one I could find:
http://www.tech-53.com/product-p/mk2-he ... unroof.htm
Lightweight
Re: Mk2 headliner
You legendteenspirit7 wrote:Some chap on Facebook just had his done.
https://www.facebook.com/groups/3916485 ... 224753481/
steve bain
Re: Mk2 headliner
i bought 2m length of this and templated it off the original one and sewed it up on the machine. its such a simple liner.
or go to a specialist who should charge you about £100 to make and fit it.
http://www.ebay.co.uk/itm/272286175735? ... EBIDX%3AIT
steve bain
Re: Mk2 headliner
you may need a bit more than 2m. maybe 2.5m. I have a storm so a and b pillars are brown.
mazellann
Re: Mk2 headliner
I had one made last year by a company local to me (in Stockton on Tees), cost me £70.
Fitted it myself, what a nightmare job, removed the rear side windows but left the front screen in, think the main problem for me was my car has an aftermarket sunroof and i just couldn't get the lining tight around it, doesn't look too bad finished.
If you can get someone to make an fit it for £100, let them do it!
x7mln
Re: Mk2 headliner
hi
i just bought a new headliner and goong to attempt to fit it myself what glue is best to use for glueing the edges in place?
thanks
thanks
Re: Mk2 headliner
are they glued?
i thought it was the rubber seal of the windows that trapped them in place and the wires running across the roof that support the middle was all that holds them in?
x7mln
Re: Mk2 headliner
yeah my old one seemed to be glued in place at the edges to the car, under the seals.
steve bain
Re: Mk2 headliner
use high temperature spray adhesive. you spray the material and the metal (about 1cm where the rubber seal sits), then stick together. then slice the excess off. you don't need to wrap it over the metal on the outside, that will cause leaks. get a pack of new stanley blades too!! if you use good adheive it grab instantly so you won't need to use bulldog clips etc. and get some window goo for when you refit the glass.
http://www.ebay.co.uk/itm/HIGH-TEMP-SPR ... rjlbqu1DHw
Personally i would take the windscreen out. not sure how else you would do it. there a couple of videos on youtube that may be worth a quick look too.
