Bottom picture - I believe is the connections for the AAV (auxiliary air valve) ISV (Idle stability valve) and 5th Injector, there should be 3 plugs?
2nd picture - I think the green plug is for the WUR should have a red/white wire and a brown wire. Brown plug is for the Thermo time switch should have a green/white wire and a red/black wire, I think the other wires with the spade connectors are for the water temp and oil temp sensors but I can't see the colour of the wires.
1st picture - Not sure, can't see where it comes from or the colour of the wire?
